Who Knew?
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Who Knew? - 11.27.2007, 04:02 PM
That sounds like a pretty simple resolution. Please come back and let us know if that works for you. Every little bit helps.
it works
lind5
Thumbs up it works - 12.17.2007, 12:41 PM
well my monster pro decided to cook itself this weekend so i had to remove it from the heatsink. It was stuck on with arctic silver and i put it in a sealed bag and threw it in the freezer over night
i gave it a tap on the side and it just popped off so thanks for the advice it did help
now i need to c if sky t will fix it or replace it
we can only hope
12.17.2007, 12:47 PM
I am also having a problem with a 125b and an 8xl. It is stuttering badly on startup and once it is moving it does not go very fast! I have a spare motor and esc and will try swapping parts until it clears up. Was wondering if you could give me S&T's contact info and shipping info in case I need to send it back. The esc is out of warranty so do they have a std charge to fix it or is it depending on what is wrong?
