Patrick
Patrick's Avatar
11.28.2007, 04:05 AM
I agree with neweuser, I think your over geared. What sort of driving are you doing? For normal driving I think you need to go down at least 2t or so on the pinion and see how that goes. If you have a finned neu, the 17t pinion might be the smallest you can use with the ofna 51t without grinding fins. 1/8th diffs will help get your gear ratio down a little bit or you could try the 65t spur off an Ofna Monster Pirate I think it is. Motor plate may need modifying for that to fit.
