Locktite
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Locktite - 11.28.2007, 10:28 AM
I don't bleieve that there is any easy solution for this one. If you used the red locktite that stuff is formulated for permanent installations, and short of destrying the hardware it will not likely come apart. It would probably be best to drill it out before you deform the area beyond repair. At least that way you will have a good surface that you can work with for drilling, extracting, and re-tapping new threads.
For the blue locktite it usually only takes a firm steady pressure to break it lose and remove it as long as you have good hardware in place and precise(hardened) tools to work with. If not then it also will be difficult to remove. Before you do any drilling you might want to wait and see if anyone else on here has any miracle treatments other then what I have suggested. Good luck with resolving this issue, and please by all means come back and share the outcome. I think it may be good to share with others who are using it so they may be a bit more particular about what they use it on. Sorry my answer is not more positive.
