entjoles
11.29.2007, 08:31 PM
i have done this same set up... in a g3r revo
my exp. was this, on 4s it cogged, it was still usable but not track worthy, the esc. also ran a little hot, caused by the cogging (???)
in my crt .5 on 3s it cogged very little and was way fast and powerfull, but it is very light compared to a mt
what is your setup???
if using a stock chassis and 2spd revo trans (requires a servo for brakes) it should be better because of the lower gearing of 1st gear
but i am not quite sure i would recomend this setup, you could try it, but if you need to buy the parts..... its up to you
