Patrick
Patrick's Avatar
12.10.2007, 08:19 AM
Originally Posted by mabu View Post
The connections are all ok, the motor tried to do something.
Yesterday i removed the clibs i had used on the motor wires - now the problem seems to be solved...
If the motor moved, but didn't spin, then it sounds like 2 wires are ok and the 3rd one has an open circuit somewhere down the line.
What do you mean you "removed the clibs i had used on the motor wires" ? Did you remove the plugs and solder the wires instead?
