12.12.2007, 09:09 PM
Could simply be a lemon servo. My first Hitec servo in my CRT.5 on 2s went bad fairly soon, but the second one is still fine.
However, on 3s, the linear regulator in the MM could be working kinda hard and heating up. If you don't have a UBEC to use, try drilling several holes in the MM plastic case to allow air to ventilate. The MM BEC is on the bottom PCB along with the USB jack.
