Grind a Neu...
cemetery gates
12.13.2007, 06:31 PM
I ground a flat spot on mine, you really need it given the amount of torque these motors produce. I also use some locktite on the setscrew. If you do those two things you should rarely have a pinion come loose.
Bye
cemetery gates
