david lamontagn
12.17.2007, 11:23 AM
If you did it , you must be certain that you can disable the brake fonction on your ESC, because when you'll brake, you ESC should not brake.
I've an MGM 16018 and i can't disable the brake fonction completly on it, i can only put it to a very low setting. SO i don't have the choice to MIX the chanel 2 and 3.
