Help with a Plettenberg please!
sikeston34m
12.21.2007, 08:19 PM
If you have a test meter handy, see if the winding has shorted to the motor casing.
Set your meter to continuity, then put one lead on the motor casing and the other lead to any power wire.
His ESC probably smelled burnt from trying to run a shorted motor winding.
What kind of connectors do you have between the motor and the ESC?
I wish you luck on this one.
sikeston34m
Find all posts by sikeston34m
