sikeston34m
sikeston34m's Avatar
12.27.2007, 01:53 PM
Yup, the little square upright "pegs" are the sensor crenellations. The sensor is a U-shaped device that shines a light from one side of the U to the other. The crenellations breaks the beam and tells the optidrive that there is movement and can even tell how fast (but not sure if the optidrive reads the speed).
I sincerely hope that if the emaxx uses a revo-like tranny design (which they would HAVE to if they want an autoshifting two speed with reverse), that they make the reverse gears far more durable. The setup in the Revo were horribly weak. Coupled with poor strength, any dust or debris that gets on the sensor will fool the optidrive into thinking that the truck is stopped when it isn't. The inside of the tranny is sealed, but all the trannys I've taken apart has some "gear dust" in there over time.
Thank you. Now I think I understand better.
The E maxx tranny doesn't have a separate set of weaker Reverse gears. This is all going to be done with 2 sets of tough looking gears. One set for 1st gear and the other for 2nd.
There is NO one way bearing since this is an Electric setup.
I believe plans are to sense the speed of the output gear through the sensor, then automatically shift to 2nd gear. I just hope they make the shift point adjustable since there are so many gearing options at the pinion/spur gears.
12.27.2007, 03:05 PM
I have a feeling that you are right Sike. It will be nice to have an auto shfting servo actuated tranny! I am sure that the control box that the sensor ties into will have some sort of adjustment "knob".
