I think all you need is the ring and pinions, but the advantages are a lower gear ratio, so you can go with a smaller spur and lower the diff (using CR buggy diff mounts and/or RC-M motor mount depending on your motor mount setup). So basically, lower center of gravity, less rotating mass, and helical cut gears.
