ncalenda
Need for Speed
ncalenda's Avatar
12.31.2007, 02:00 AM
Originally Posted by squeeforever View Post
Your gonna have to compromise if its gonna pull double duty. The diffs, setup correctly, aren't gonna be ideal for both. Its one or the other. Usually brushless is gonna require a good bit heavier fluid in the center, and slightly heavier in the front and rear.
What would you recommend? I was going to try 7/15/7 (stock is 7/10/7)/
Are you thinking maybe 10/20/10??
I bought a 2nd center diff so that I could test diff ones.
  Send a message via AIM to ncalenda
