rchippie
rchippie's Avatar
01.01.2008, 01:41 AM
Originally Posted by starscream View Post
It depends on how you mount them. The kokam's basical sit flat on the chassis with just a touch over. I mount mine in a plsatic case which goes over the side ~1/4 inch but still fits fine under the body and is protected in hard plastic. If I mount the kokam's on their side, they will not hang over the edge naked or in the plastic case.
So will the maxamps 2s packs hang over the chassis slightly if i lay them flat & not if i put them on there side ?. Also will the mini servos work on this chassis if thats all you have ?.
REAL MEN RUN BRUSHLESS
