BL-Power
BL-Power's Avatar
01.05.2008, 02:55 PM
The batteries are charged to 15,5V and the Lipo cutoff is set to 12V. The problem is also existing when i use my CC UBEC, so i don't think that the problem are the RX batteries
 Send a message via ICQ to BL-Power
jhautz
jhautz's Avatar
01.05.2008, 03:19 PM
is your radio throttle centered? If you arent in the neutral position some ESCs have a fasty built in so they dont just runn off on you when powered on and the throttle isnt at neutral.
If you not sure you could try seting your radio trims and EPAs to 0 and recalibrate the esc to the radio. its possible there is something out of adjustment that the esc doesnt like.
to make it...
or break it...
Silent...But Deadly
BL-Power
BL-Power's Avatar
01.05.2008, 03:32 PM
The radio throttle is centered, everything is ok. Tomorrow my cousin is visiting me, i'll try if the MM works with his 2,4GHZ Futaba radio.
jhautz
jhautz's Avatar
01.05.2008, 03:40 PM
try redoing the radio calibration on the MM. It cant hurt.
to make it...
or break it...
Silent...But Deadly
BL-Power
BL-Power's Avatar
01.05.2008, 03:43 PM
I can't calibrate it, it is just doing the same damned flashing if i switch it on with full throttle.
jhautz
jhautz's Avatar
01.05.2008, 03:54 PM
check to see if it is plugged into the rx properly or if there is a loose connection somewhere? Maybe is not seeing the receiver and therefore not arming all of the way.
to make it...
or break it...
Silent...But Deadly
