Please could someone point me at the sticky re gearing and temps
Please could someone point me at the sticky re gearing and temps - 01.15.2008, 01:39 PM
Trying to balance blowing up MM on 4s (I think due to cogging) and high motor temps.
I'm going to try direct soldering the motor leads but when I did my last test run motor was V hot to touch esc was cool...
This is for my MBX5 (MSR T) i.e. buggy diffs - 16/46 on 9XL 4S with MT Badlands.
Differential Ratio: 3.3333333333333335
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 16
Total Voltage: 16
Motor KV: 1853
Tire Diameter (inches): 5.25
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.0092
Spur/Pinion Ratio: 2.88 : 1
Total Ratio: 9.58333 : 1
Tire Circumference (inches): 16.49 inches (418.93mm)
Total Motor Speed: 29648 RPM
Vehicle Speed: 48.32 MPH (77.62km/h)
Effective Speed Rate: 3.02mph/V (4.85kmh/V)
Effective KV Value: 1853
I thought hot motor / cooler ESC was undergeared... It feels quick but not this quick...
Serum
Serum's Avatar
01.15.2008, 04:16 PM
http://www.rc-monster.com/forum/showthread.php?t=2200
it's in the FAQ.
bdebde
That's All Folks!
bdebde's Avatar
01.15.2008, 04:19 PM
I think you are over geared with the buggy diffs and badlands (aren't they closer to 6"). I would try 13 or 14 teeth on the pinion.
01.15.2008, 04:23 PM
http://www.pro-lineracing.com/howtot...arison.html#mt
Yes 6.1!
Other Ratio: 1
Total Voltage: 16
Motor KV: 1853
Tire Diameter (inches): 6.1
Tire Circumference (inches): 19.16 inches (486.76mm)
Vehicle Speed: 56.14 MPH (90.18km/h)
Effective Speed Rate: 3.51mph/V (5.64kmh/V)
I think i might need to go down to 10!
Other Ratio: 1
Pinion Tooth Count: 10
Total Voltage: 16
Motor KV: 1853
Spur/Pinion Ratio: 4.6 : 1
Total Ratio: 15.33333 : 1
Vehicle Speed: 35.09 MPH (56.37km/h)
Effective Speed Rate: 2.19mph/V (3.52kmh/V)
BL-Power
BL-Power's Avatar
01.15.2008, 04:24 PM
At at total ratio of 9.58333 : 1 i'm not surprised that you have a hot motor. For your vehicle, a total radio between 13 and 15 would be normal, a 11 - 13 teeth pinion would be perfect and your motor will stay much cooler. And if it's too slow for you, go up to 5s if your MM is able to handle this voltage.
 Send a message via ICQ to BL-Power
01.15.2008, 04:37 PM
I would go with a 12 or 13t pinion for your setup. Your motor speed is a little slower than optimum, and 16v is a bit optimistic to expect from a 4s pack under load, I usually stay with the nominal voltage for lipos, as it gives a better indication of voltage under load. I do not think you will have any issues with the vehicle geared for 38mph or so. I would use the 13t, but you may want to go down to the 12t.
01.15.2008, 05:51 PM
Bought an 11T to start with
Other Ratio: 1
Pinion Tooth Count: 11
Total Voltage: 14.8
Motor KV: 1853
Spur/Pinion Ratio: 4.18 : 1
Total Ratio: 13.93939 : 1
Total Motor Speed: 27424.4 RPM
Vehicle Speed: 35.7 MPH (57.35km/h)
Effective Speed Rate: 2.41mph/V (3.88kmh/V)
crazyjr
crazyjr's Avatar
01.15.2008, 07:35 PM
I always thought hot motor, meant undergeared. hot esc was overgeared
