Look what i've found on MGM website!!!!!!!!
david lamontagn
Lightbulb Look what i've found on MGM website!!!!!!!! - 01.18.2008, 11:46 AM
Somes guys here have got somes problems with the MGM Low Voltage Cutoof who kick in too early.
Please reed it and tell me if we can did the same to lower the LVC on the controller (16018 or others) to solve the problem with li-po pack
Reed it carfuly please
http://mgm-compro.com/pdf/en-a123sys...ollers-tmm.pdf
David
david lamontagn
01.18.2008, 11:56 AM
If i make their calcul, i suppose that if i set the MGM16018 LVC in Nixx and adjust it at 1.17, i'll have a LVC of 3.0v/cell for a 4s li-po pack.
Please if some body can try it, because here in Quebec, we have 4' of snow outdoor, and i can't try it.
So if somebody run a 4s setup on his MGM can programm his MGM controller and set the LVC in NiMh mode, and place a 1.17 value, and try it just to see if the LVC willl kick it on hard acceleration, and when the pack will be dump, check the cell voltage.
83gt
01.18.2008, 12:08 PM
I'll give it a shot tonight or tomorrow. I've been running in race mode to prevent the early cutoff.
J.
david lamontagn
01.18.2008, 12:23 PM
OK good, and please don't forget to tell us the result
Cartwheels
01.18.2008, 01:37 PM
Do you always round up on #3? That would be the question I would have. Thier examples they are always greater than .50 in fact much higher. So, if you are at 10.20 do you still round up?
01.18.2008, 03:13 PM
Rounding is usually done by going to the next highest integer if the fractional part is greater than or equal to 0.5 - otherwise round down. If you want to play it safe, round down.
david lamontagn
01.18.2008, 03:46 PM
My calculation for 4s li-po si this one:
3.7v/cell X 4 cells = 14.8volts
14.8volts / 1.45 = 10.2 (i didn't round down, i just keep this number to be the most precise possible)
0.8 X 10.2 = 8.16V
1.16 X 10.2 = 11.83V
8.16V / 4cells = 2.02V
11.83V / 4cells = 2.96V
So if i want a cutoff voltage of 3V / cell, i just do this : 0.8 = 2.04V
? = 3.00V
? = 1.18V
So i set the MGM cutoff in Nixx mode and adjust it at 1.18V
If all is OK, the controller will suppose to cutoff at 3.0V/cell or 12V (1.18V X 10.2 = 12.036V) for the total pack.
I re-read the instruction of the owner manual of my 16018, and the MGM controller don't use the same method of others controller to ""watch'' the cell voltage.
83gt
01.18.2008, 06:50 PM
Well, I would have tried it, but my mgm is gone. I had some wierdness from it a while back when it let out some smoke and quit working. I was about to send it off beginning of this week, when I thought I'd try it once more. I found out that it had just burnt out the BEC, and still worked with an RX pack. I was playing with the programming to try this just now, and when I turned it on, it let out a little more smoke. Now I think it's totally gone. I'll be sending it off hopefully to get repaired.
J.
BashOn
02.11.2008, 03:08 AM
David
I program my 22418 via my computer and I have no area to set the cutoff voltage when I select NiCd cells.
Anyone figured out how to do this?
david lamontagn
02.11.2008, 12:21 PM
Excuse to all guys here, i've recieve an email from MGM and it's just with the Airplane/helico controller that we can set the LVC on Ni-xx mode.
VWT4
02.11.2008, 01:24 PM
I asked the same to the MGM team and the answered:
In current Car/Boat versions are no possible set "cut-off voltage", here is fixed value ca 0.85V/cell (Nixx) --> it is ca 2.2V/cell A123.
Nixx batteries have only automatic number of cells setting (this value is no critical for Nixx) - this is applies for all controllers, no only for car/boat. When you will start with charging A123 cells, cut-off value for A123 will be correct.
I undestand that programming for nixx cells will work for a 2.2V cutoff using any number of A123 cells.
