A4DTM
01.14.2008, 07:48 AM
haha, no prob. i got them a few months ago for my project :)
only problem on my truck, is the 1/8 buggy rims rub the shocks, but 17mm mt rims work fine.. and my trucks an mt2 not a ls10, so idk if that'll be a factor.
rootar
rootar's Avatar
01.14.2008, 08:51 AM
i cant get newera's site to work, im gonna try it at school later, but from the looks of that picture they are exactly what we are looking for.
01.14.2008, 10:14 AM
I can't seem to make the site work either, guess I will try back later.
ClodMaxx
hold my beer... watch this...
ClodMaxx's Avatar
01.14.2008, 10:20 AM
ross, PM me your address and i'll send you a set of the axial adapters you linked earlier. i have 2 sets i can't use that came with my axial narrowed 40 series beadlocks i got for my crawler. you can see if they'll work. if not, pitch 'em.
Eflite Blade 400 heli on 3s
Duster_360
01.14.2008, 07:15 PM
Wasn't working for me earlier today, but it comes up now.....
ClodMaxx
ClodMaxx's Avatar
01.15.2008, 01:05 AM
my bad. the axial adapters are 6mm, not 5 (made for an emaxx).
rootar
rootar's Avatar
01.17.2008, 10:44 PM
i got my vantage 1/8th scale wheels in today (im digging the spokes) and the newera adapters should be here tomorrow, i havent bought tires yet since i not sure wether to go with the crimefighters or something else. i dont see me having any clearance issues the wheels have a TON of room compared to the 2.2 truck wheels, i could check this to make sure if you (A4DTM) could tell me how far the outside face of the buggy wheel sits from the drive pin in the axle......that would be alot of help thanks ahead of time
A4DTM
01.17.2008, 11:47 PM
14.00mm from inside hex surface, to outside wheel face
28.80mm from inside hex surface, to inside wheel rim
75mm inside dia.
edit. i hope that's what you mean
rootar
rootar's Avatar
01.18.2008, 01:28 AM
yea im trying to figure out how far out on the axles the wheel will sit when i get the adapters on there. so its about .55 of and inch (14mm) to the outside face of the wheel from the drive pin hole in the axle?
snellemin
2 KiloWatt RACER
snellemin's Avatar
01.18.2008, 01:33 AM
I don't know if I'm too late with this, but I had seen 12mm-17mm hex adapters. These were no extensions, just hexes that went over the 12mm ones. Then there are these washers that go on the outside and gets fasten with the bold.
12-17mm adapters
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
ClodMaxx
ClodMaxx's Avatar
01.18.2008, 01:37 AM
there are all of these as well.
01.18.2008, 04:47 AM
12-17mm adapters
Out of that list, these look like the best bet. I will give my maximizer 12-14mm adapter with the gs racing 14-17mm adapter a try and see how it does on the crt.5.
rootar
rootar's Avatar
01.18.2008, 06:01 PM
do they make 1/2 inch offset BUGGY wheels? i got my adapter on there and the truck is and inch and a half narrower.....nothing rubs but id like it to be as wide as it was with the 2.2 wheels
A4DTM
01.21.2008, 07:01 AM
good question.. bump.
rootar
rootar's Avatar
01.21.2008, 09:53 AM
after seeing them on linc's Hyper-pede i looked and found Low Profile panther komodo dragon tires that are 5 inches tall (these are supposed to be very light and small for a truggy/Mt tire and mount on a 3.3" wheel (such as the Jammin's).Then i could get the truggy wheels in which ever offset i needed.......Lincpimp is helping me find out more on the tires and wheels.
