14T pinion sounds undergeared to me. If your motor is hotter than your ESC, that's most likely your problem. 140F on the motor is honestly nothing to worry about. Demagnitization only happens around 200F, so you're fine. I'm pretty sure the endplay you felt was there all the time. Upping the voltage will help, but then you run into troubles w/ ESC and buying a new battery.
