GriffinRU
01.23.2008, 06:20 PM
Originally Posted by ib4200 View Post
you make bigger caps sound like a bad thing...
They do help battery but not much for ESC...
In MM case above 4S and with higher currents caps start to overheat and once their temp goes up all the good things they used to do for ESC vanishes away. Following with failures first and smoke second...
Also "bigger" caps are not always better then smaller ones, there are specific parameters and placement which makes them good.
