Shark413
Shark413's Avatar
01.24.2008, 10:47 PM
I was finally able to get everything together. Took all the parts off the standard chassis and added them to the extended chassis. Installed the battery tray, ESC and rx. Added some foam padding for the battery tray, a rear skid plate, new servo saver arm, Hitec 5645MG servo, linkage, etc. Now if it would only stop raining I could take it for a spin.
Current configuration:
Mamba Max, 7700 motor, FASST rx, extended chassis, 13T harden steel pinion, 46T steel spur, Proline CF, Maxamps 2s2p lipo.
Battery tray without the foam padding
EVA foam 1/4 on the bottom, 1/8 on the side.
Top view
Bottom, notice the battery tray uses the stock motor mount holes.
With a 2s2p lipo strapped in.
