jhautz
jhautz's Avatar
01.25.2008, 12:41 PM
Mines 10.3lbs with 5s 5000mah and a Neu 1521
to make it...
or break it...
Silent...But Deadly
david lamontagn
01.25.2008, 05:01 PM
realy don't know how you did it
I've only a 4s 5000mAh and i'am over 11 pounds.
Now i'll make the same setup as lonewolf039, but instead to take a center diff, i'll take the stock revo output shaft on the stock tranny, build an adapter to fit the spline on the shaft and bolt a 46t steel spur on this adpter.
And i'll put the stock mechanical brake system on it.
I've tale a look on it yesterday night, and the bigger part to do will be the mount for the motor.
I'll order two RCM revo hybrid diff (truggy ratio) and run it on 4s, with the Tekno elektri clutch adapter and a 16T clutchbell.
