jhautz
jhautz's Avatar
01.27.2008, 10:52 PM
One more problem I ran into is if you use the spacers on one side TVP to give more battery room the pins that engage the TVPs on the front and rear bulk heads dont mate into the hole. I had to pull the 4mm pin out and I put a little spcer in the hole to keep the pin from going all the way in. I just pushed a short 4mm grub screw in there to keep the pin from bottoming out in the hole. This allowed it to stick out far enough to engage the TVP. It needs to be done on only the side you are using the spares with and only if you use the spacers.
I also needed to open up the hole on one of the spacers to 5mm so it will fit over the 5mm metal threaded insert in the bulk heads.
to make it...
or break it...
Silent...But Deadly
