gear ratio's direct drive emaxx tranny
sly118
gear ratio's direct drive emaxx tranny - 08.28.2005, 12:03 PM
hi there , ive converted my UE - maxx to a direct drive centre gear from a ofna 1/8 buggy but now im stuck with matching a gear ratio , please help with suggestions , currently got 9L with 20 pinion and 66 spur and that was sweet , centre diff has 46 spur atm but ill have to wack a 51 tooth plastic spur on .. but what pinion ?? also have to keep in mind the ratio change from the tranny . b4 it was 1.75 turns of spur = 1 turn of output shaft , but now its 1=1
please help ?? mike ? any ideas ?
Serum
Serum's Avatar
08.28.2005, 12:37 PM
w[- lc0m[- 2 t|-|is f0ru/\/\ /\/\8!!,
it sure took me some time reading your post, but I finally get what your saying (i'm foreign, don't blame me)
The best you can get is a 10 tooth pinion.. with how much cells are you driving your truck? (end ratio of 16.9 to 1 )
The ratios are somewhat limited with those centerdiffs!
sly118
08.28.2005, 12:44 PM
yeh i was guessing 10 tooth would be anout right , ill probly also buy 12 t too .. one guy is running big maxxium plettenburg with 12/51 combo with similar drive setup .. i only running 12 cells , as that is what our rules say in racing .. i was also thinking of getting a 10L as it has lower rpm / v and i could run the slighty taller gearing . anyone else had any experiance? ( should be a bullet proof setup , drops 80grams off weight also lowers centre of gravity by heaps ,
Serum
Serum's Avatar
08.28.2005, 01:10 PM
I would use a 7XL on 12 cells with the centerdiff. (or on 14 cells as well)
sly118
08.28.2005, 01:21 PM
have to see what i can come up with , i might look into adapting a stock 66 tooth spur to the ofna centre , and run a 12 t pinion as that equals 10/51 in mod 1 pitch ( but just noticed that mike only goes down to 14 t 32P 5mm shaft , damm migh just have to get a 10t and try it ..
Serum
Serum's Avatar
08.28.2005, 01:25 PM
Don't you know anyone with a lathe?
making the 3.2mm hole 5mm is rather easy..
I'm not sure how the pitch 32 gears hold up the power..
You could also get a 72 tooth spur (if that fits the frame)
MetalMan
MetalMan's Avatar
08.28.2005, 04:26 PM
At one point in time I was experimenting with using T/E-Maxx diffs on a custom monster truck with "direct drive" (just pinion/spur for reduction), and I found that for a Feigao 8L, even 12/72 was barely a low enough ratio. But that was with a motor spinning 40,000RPMs at full throttle. I gave up on that project due to the complexity of getting the custom bulkheads/a-arms/general parts machined well enough to fit together, while getting these parts for a low enough price.
coolhandcountry
coolhandcountry's Avatar
08.28.2005, 04:48 PM
Let me get this straight you running a 66 spur and 20 pinion with 1.75to 1 ration tranny. That would make the spur and pinion ratio at 3.3to 1 x 1.75 to 1 ratio = 5.775 ratio. Maxx bling ran a 56 ofna second gear spur. with 10 tooth pinion would put you at a 5.6 to 1. A slightest bit higher but with the weight lost should be good.
Peace!
Country
Help support the
Rc-Monster
Buy here
Serum
Serum's Avatar
08.28.2005, 04:59 PM
Yea, i don't see no problems either.
I am currently cooking a new project, it uses some words as ; centerdiff, 20cells, 9XL, savage suspension/drivetrain and a flat based design of frame.. (with less aluminum than my other cars, i need one for pure bashing..)
coolhandcountry
08.28.2005, 05:09 PM
I like to see some pics of that serum. That sounds like it would be awesome.
Peace!
Country
Help support the
Rc-Monster
Buy here
Serum
Serum's Avatar
08.28.2005, 05:17 PM
I will start a topic about it, once i get my savage .. (it might take a week or two though..)
I don't know what to use for the frame, aluminum or CF, CF is nice but i have got no expreience working with it, my guess is it takes a high rpm with a small diameter bit to route it.. (just like epoxy board)
I am cooking on some plans as we speak, it will be low cg and a truggy like design (like a gmaxx converted emaxx) only with a longer frame, capable of holding 10 cells on each side
coolhandcountry
08.28.2005, 05:21 PM
You going to shot for about he length of mine there serum. I can tell you it handles great. I will wait and see.
Peace!
Country
Help support the
Rc-Monster
Buy here
sly118
08.28.2005, 06:41 PM
yes max bling running 56/12 but what is the specs on his motor , im sure it would out torq a 9L 2-pole , as his is 4-pole , and yes i could go bigger spur but that means grinding out the side of the chassis braces , and/or raising the diff centre , which puts a great angle on the drive shafts , also higher centre of gravity , i will get pics later and post them but i think ill have to just try with 51/10 and hope for the best
coolhandcountry
08.28.2005, 07:15 PM
It will gear you up a little more. Try it. You may like that setup better now that you lost some weight. Have to let us know how it turns out.
Peace!
Country
Help support the
Rc-Monster
Buy here
sly118
08.29.2005, 01:25 AM
oh i also run imex pinns , which are less diameter to stock maxx tryes ( eg bowties ) these pinns are awesome on blue groove / hard pack !!
