crt .5 body mount
crt .5 body mount - 01.28.2008, 04:23 PM
What do ppl use - I broke off one on a rollover and now it looks like I have to buy the wing mount / front bumper to replace...
Is that correct?
Thanks
MetalMan
MetalMan's Avatar
01.28.2008, 05:07 PM
Yep, you have to buy that whole parts tree. Just last night I had to replace one of the front body posts.
entjoles
01.28.2008, 06:01 PM
i got some 1/10 or 1/12 on-road style like a pan car, easy to mod and cheap, just cut em to the right length and use the nut on it under body, then drill a very small hole for the clip
01.28.2008, 06:58 PM
Could you pop up a pic please? thx
entjoles
01.28.2008, 07:22 PM
its by no means pretty , but it seems to work well, the body post pics are on the first page, i think they were bolink 2.5 inch, cost like $3
http://s170.photobucket.com/albums/u270/entjoles/
entjoles
01.28.2008, 07:39 PM
i also thought about contacting the monster about making them in aluminum, i know pretty much everyone here would buy them for their crt .5
in fact.....mike if you read this , id like a set of these if its possible to come up with something, although i have no way to draw these up
02.01.2008, 03:08 PM
Came up with a different plan - Chopped off a set of traxxas pede/rustler mounts.
Dremelled a flat section (cutout) so they rest flat against the tower - with a lip.
Then drilled a 2.5mm hole through them and threaded a 3mm machine screw through it with a lock nut on the back.
For one of my hacks it actually looks pretty good!
