jzemaxx
01.31.2008, 11:55 PM
Here is the spec sheet... for the MM5700's of course 2 of them....
Differential Ratio: 2.8461538461538462
Transmission Ratio: 1.83
Other Ratio: 1
Spur Tooth Count: 62
Pinion Tooth Count: 22
Total Voltage: 11.1
Motor KV: 5700
Tire Diameter (inches): 6.7
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 2.82 : 1
Total Ratio: 14.67839 : 1
Tire Circumference (inches): 21.05 inches (534.64mm)
Total Motor Speed: 63270 RPM
Vehicle Speed: 85.92 MPH (138.01km/h)
Effective Speed Rate: 7.74mph/V (12.43kmh/V)
Effective KV Value: 5700
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Although I highly doubt that 85mph will be done with only 2-11.1V's....lol.
Here is the 6L's.....
Other Ratio: 1
Total Voltage: 11.1
Motor KV: 4096
Motor coil Ω: 0.0043
Total Motor Speed: 45465.6 RPM
Vehicle Speed: 61.74 MPH (99.18km/h)
Effective Speed Rate: 5.56mph/V (8.93kmh/V)
Effective KV Value: 4096
And lastly the 1515 1D's, which are $$$$.
Other Ratio: 1
Total Voltage: 11.1
Motor KV: 4100
Motor coil Ω: 0.0025
Total Motor Speed: 45510 RPM
Vehicle Speed: 61.8 MPH (99.27km/h)
Effective Speed Rate: 5.57mph/V (8.94kmh/V)
Effective KV Value: 4100
Originally Posted by SpEEdyBL View Post
Two 5700s will will do it. If one 5700 is enough to push a 5bl truck to 65 mph, two 5700s will be able to push a 10lb to the same speed even easier since there is less than twice the wind resistance. The velineon motor btw is closer to a cm4600 motor, so that is not an alternative.
I recommend that you DO NOT get 6xls or 7ls or you will need twice as much batteries. Batteries supply the power. NOT the motor. Also you want to limit the rotational mass as much as possible.
Also, when you decide on batteries, try to get the biggest cells you can without having to put them in parallel. For example, two 3s1p 5000 mah packs would work better than two 3s2p 6000 mah packs.
