02.03.2008, 07:08 PM
Plus the lower kv should help with startup and overall amp draw. BL-Power seems to be having good success with a turnigy outrunner, but he is using 8s lipo, which cuts the draw in half compared to your 4s setup. You batts should be capable of 90amps or so.
Let us know the tire diameter, diff ratio. That with the battery info should allow me to make a decent choice of motor. What esc wil you be using, a mamba max?
