neweuser
neweuser's Avatar
02.14.2008, 06:38 PM
If the total pack mAh and C are the same, it shouldn't matter. 2p @ 1Ah is the same as 1p @ 2Ah.
However, if the 1p pack is made of one 1Ah cell, and the 2p is made of up two 1Ah cells, the 2p pack will perform better.
So the performance would be the ah of the cells. For example: if the 1p is 1ah, but the 2p is 2ah, obviously the 2p would perform better. But if they are the same ie: 1ah cells, then performance is basically the same. Correct?
