dklst
02.20.2008, 07:27 AM
do u have a diagram of running them in parrallel? that will increase the runtime rite? Is there any other benefits?
sikeston34m
sikeston34m's Avatar
02.20.2008, 08:29 AM
Check out Brians page here: http://www.scriptasylum.com/rc_speed/_lipo.html
scroll down to the section "Battery Pack Wiring". Then click on "use 2 parallel battery packs"
Yes it will increase runtime by doubling the available mah's of capacity.
Let's say you are running 2 packs parrallel. Each pack is a 10C 4S1P 4000mah Lipo capable of 40 amps continous discharge.
In Parallel, they will supply 4S voltage at 8000mah and be able to deliver 80 amps continous working together.
I hope this helps.
