lutach
lutach's Avatar
03.20.2008, 01:41 PM
I just finished trying my truck with 5S and it's still freakish fast. I have attached the graph of the run. It took a while for me to start running the truck as the wind is blowing at around 30MPH and it blew my hat off. I also had to switch 2 of the wires. At 3:30 sec my hat flew off again .
Name:	BPP, Schulze 40.160H, Neu 1521 1Y and 2 5S 4900mAh TP Extreme Parallel.jpg
satttheman
satttheman's Avatar
03.20.2008, 05:33 PM
I just ran mines on 5s today also it still runs nice I used my new battery which is a polyquest 4500 30c pack its killer
Projects:
FLM Savage
satttheman
satttheman's Avatar
03.21.2008, 01:01 AM
the wire from the battery makes the esc look like 16gauge or some crappy speaker wire
Projects:
FLM Savage
bluonyx
03.22.2008, 12:33 AM
Satttheman, did your 1521 come with a 8mm shaft? If not did you have to special order for the 5mm shaft? If it is 8mm,, where did you get a pinion for it?
I wanna do a 1521 on 5S. I can get two 5S 5000mah packs and run them parallel for 10000mah total on 5S. That should run me hopefully an hour on my LST2.
satttheman
satttheman's Avatar
03.22.2008, 01:37 AM
I got it from mike he should still have them in stock
Projects:
FLM Savage
bluonyx
03.22.2008, 12:10 PM
I ran my Muggy for the first time this morning and i wasn't that bad. I'm running a 8XL, MM, 4S, 18T Pinion, stock gearing. Fully loaded it weighs in at 11.5 lbs., it seemed really fast and balloned the 40 series Big Joes easily, but the temps were a little too high for me. The MM was 160, motor 160, Lipo 120.
I switched to a 16T and the temps went down. MM 125, motor 140, lipo 105. It probably didn't help that I was running Bog Joe tires too. They seem way too heavy for this setup, but I liked the way it handled. A big difference from my LST2.
Does anyone have the weight for one stock Muggy tire and rim?
bdebde
That's All Folks!
bdebde's Avatar
03.22.2008, 05:51 PM
stock muggy wheel/tire is 329 g, or about 11.5 oz.
bluonyx
03.22.2008, 08:35 PM
Wow I thought there would be a bigger difference.
Thanks bdebde, a 40 series big joe and velocity rim weigh 14oz., 2.5oz. isn't that big of a deal. I might as well keep them.
satttheman
satttheman's Avatar
03.22.2008, 09:54 PM
that's alot that's almost 3/4 lbs of rotating mass
Projects:
FLM Savage
BlackedOutREVO
04.02.2008, 08:38 PM
I think I almost crapped myself!
That is a huge truck, and the motor flings it around like it weighs nothing!!!! I love it! I NEED ONE!
supralover72
supralover72's Avatar
04.02.2008, 08:53 PM
Very nice dude! That thing is a BEAT! I thought dinosaurs were extinct!
satttheman
satttheman's Avatar
04.04.2008, 02:09 AM
thanx. I got to make a vid of my 3905 emaxx it crazier!!! I like to overpower everything
Projects:
FLM Savage
ReV:-O
RC-Monster Carbon Fibre
08.04.2008, 05:33 PM
so if you buy the brushless motor mount, it replaces the brake servo? does this mean you can only use motor brakes and not mechanical brakes?
how would using motor brakes work with a center diff?
thanks
bdebde
That's All Folks!
bdebde's Avatar
08.04.2008, 05:42 PM
Motor brakes work fine with a center diff, just need to go a little heavier weight on the center diff fluid. Mechanical brakes can be done with a spacer in front of the motor, if you have to have mechanical brakes.
ReV:-O
08.04.2008, 06:42 PM
with a spacer infront of the motor? how would that work seeing as there isnt a servo there anymore? i will probably just use motor braking but i am still curious as to how mechanical braking would work
