RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
09.03.2005, 12:17 PM
I used the g-maxx front skidplate, a stock rear skidplate and the UE rear skidplate to make the custom skid(used these to line up the chassis braces with the ext. length and get the hole locations for the rear bulkless). I basically drilled the UE mount holes into the g-maxx skid and cut away the excess material on the outside.
The scorpion packs have the voltage cutoff built in. The scorpion charger allows quick charging as well(astroflight doesn't). That is indeed the astroflight charger I use.
The 6400mah packs will get you through the 10 minute mains. You should lap the nitro guys if you can drive well enough.
