SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
02.23.2008, 04:28 PM
Originally Posted by Sower View Post
The only thing I can say here is that the intention for most people to go with the 6s vs 4s isn't the "more power" argument as much as efficiency. By reducing the amp draw with higher voltage things just run better. I have no problem with the 2200 motor except on 6s. Some people may be fine with it, but I feel it's outside the motor's ideal efficiency. Especially if you're looking to race. Otherwise I'm sure you could have a lot of fun with it. I mean heck, who wouldn't think it's cool to see a 1/8 truggy blasting by you at 70mph?
Like I said, the neu motors are efficient enough that you dont need to worry about running it in their "efficiency range." That was only true for feigao motors. At most power levels you don't need 6s to still have a very efficient setup. The mmm will still handle the amp draw of a powerful 4s setup (btw if the mmm can handle its own motor on 6s, it definately can handle same motor on 4s). That said, I don't see why people would have any problems running the 2200 on 4s for racing. As motors and escs advance, the benefit of running 6s vs 4s at a given power level becomes less and less, especially when the amp rates are well within the escs range. Although power loss is rI^2, the resistance of the motor increases by the square as kv increases. So a 1515 1.5y on 6s is theoretically going to create the same amount of heat as a 1515 1y on 4s at the same power level, because the 1.5y has 2.25 times the resistance.
Benefits of running 4s vs 6s are:
1. Bigger lipo cells holder ther voltage better C wise. So a 6000 mah 4s pack made up of 6000 mah cells is going to hold a higher voltage per cell at 60 amps than a 4000 mah 6s pack at 40 amps.
2. There is less of a possibility for one cell to go below the safe voltage in a 4s pack than in a 6s pack, unless you moniter each cell individually (most cutoffs dont).
In the end, you really do only need 6s for power. Is it better to have two motors or two packs? You can charge one while running the other if you do have two packs. I can only see the 1515 1.5 being absolutely necessary if the 1y is already too much on 4s.
Area 52 Ranch Raceway
T.R.C.R.
