02.26.2008, 07:10 PM
Originally Posted by ssspconcepts View Post
Just curious...in an earlier post you indicated that the spur was too far away from the motor plate. How did you address this issue? I recall that you could address it one of two ways...drilling another hole in the input shaft and adding a small plate to address the gap.
Well, what if you used a RC Monster 18T mod1 steel pinion (they also have a 5mm bore and will fit on the revo input shaft) in place of the stock emaxx 18T gear (its a mod 1 pitch too right?)? Then you wouldn't have to drill any new holes in the input shaft...just break out the dremel and flatten a small spot on the shaft and then adjust to the correct position and then red lock tite. Voila! adjustable input shaft....would it work?
It works fine, this is what I did to my tranny and have not had any issues, just make sure that the flat spot is just the right size, so that the gear cannot slide down the shaft.
