That diff could be adding some weight. And, your deffinetly going to need a chassis brace in the rear if you plan on jumping this this.
Why would the diff be adding weight? because of the metal spur? or is a spider heavier then a regular?
As for the rear chassis brace, I know, I am in the process of making one, the stock one won't fit with the motor being centered.
