GO-RIDE.com
03.02.2008, 02:48 AM
I'm having some issues with differential oil weights. I have two problems.
1. The back end of the car kicks pretty badly in whoops under 3/4 throttle or higher. Not too bad at 1/2 throttle or lower.
2. Exiting turns on power it develops a bad push and gets worse the more power you try to use.
I've tried both the follow oils (F/C/R) 3/3/1 and 2/4/1. The 3/3/1 seemed to be a bit better, but not a big difference. Any recommendations?
E-8ight - Tekin RX8 2000kv/4S
