glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.04.2008, 11:35 PM
I just run a similar setup to what the nitro guys are using... typical buggy oils are in the
5-7-2 ballpark, give or take a little. I wouldn't go over 10k in the center. 7-10-3 is probably the heaviest I would try.
Common starting point for truggies seem to run about 7-10-3... but some do go heavier.
I have not experimented that much with the diff fluids, but I'm going to this summer a lot more.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
