Dafni
Dafni's Avatar
09.05.2005, 08:53 AM
Nick, weight is nothing else than a force pushing downwards. So if you have a force pushing upward, you can subtract this from the "weight".
I could bother you with talk about gravitational constants and difference between "mass" and "weight", but I won't. Life can be so simple, but there is always a way to make it sound complicated.
(don't want to sound braggin', but sometimes nerdiness just takes over)
Serum, I could also calculate the buoyancy of 4 Helium filled tires, but I will spare you. It's most probably not even enough to lift a small 3mm screw.
Dafnerd
