MetalMan
MetalMan's Avatar
03.06.2008, 04:31 PM
MGT spur gears, with 3 of the slipper peg holes drilled out to 5mm and with washers under the screw heads to keep the gear from sliding off, fit on the Revo slipper clutch perfectly. I've used them on several Revo slipper clutch plates, and it works perfectly every time. The gears come in sizes up to 52t, and they are mod1.
