bluonyx
03.11.2008, 01:26 AM
You can solder directly to the ESC if you want or just buy some bullet connectors. And you can Dremel a flat spot on the shaft. Just watch out for metal shavings going into the motor. You can use a small ziplock bag, put the motor in and poke the shaft through the bag, this should protect the motor. At least that's what I do, and works for me.
