david lamontagn
03.13.2008, 05:13 PM
Yes, you can put it on the input battery lead, just solder it as close to the ESC as possible.
Larger values of capacitance is fine, it will just be physically larger and create a larger hook-up spark. An increased voltage rating is fine too.
If you look closely on the MM board, where the input lead is solder, they've somes littles holes, just beside the + and the - lead.
And surprise, this holes have exactly the same diameter of the capacitor wire.
So i'll just have to slid each capacitor wire in this hole and put a little dab of solder!!!!!
More, this hole is very close to the input lead, so maybe i'll just heat the solder on the input lead and this will melt with the capacitor wire.
But for sure, this 50V, 3300uF is huge
