03.13.2008, 06:02 PM
You mean the assy numbered 66479? The pin should have a flat spot where the set screw contacts it. That is just the same as the old lsp. Good threadlock and a good hex driver should help you get it tight. The heatshrink is not a bad idea, as it should contain the pin if it starts to fall out.
