mothman
09.06.2005, 08:20 PM
Its not only the savage, most of the nitor tranny dont have reverse.
Gustav
Gustav's Avatar
I think on the Savage it has a single spur and shifts internally.
but yes you'd need mechanical reverse and brakes.
I thought there was a reverse module you could add to the savage.
toby
toby's Avatar
09.06.2005, 08:22 PM
this is a whole new thing now. i do not know how to hook up brakes. i do not need brakes right a way though but i will by after winter time
rc18mt/blade cp
Gustav
Gustav's Avatar
09.06.2005, 08:27 PM
The brakes would just be the same as they are as a nitro.It's just if you want to have a multi speed tranny it needs a one way bearing so you can't apply a force on the shaft in the opposite direction for reverse or braking like you normally would with the solid shaft/no one way bearing on an electric.
toby
toby's Avatar
09.06.2005, 08:28 PM
is it easier to lock out first than?
rc18mt/blade cp
Gustav
Gustav's Avatar
09.06.2005, 08:37 PM
I think Serum is the best person for this,but i'm sure it's easy to fit a locked shaft.You really only need one gear with brushless because they have so much torque you can effectively drive it in top gear all the time.
If you did want 2 or 3 speed (which i'd say you don't really need) you need to think of the motor just doing the same as your nitro motor.so you'd need a servo for braking and a servo for reverse(if you have reverse).
Serum
Serum's Avatar
09.07.2005, 02:22 AM
You really don't need a two speed actually, its just for the extra punch.. So a 3 speed is complete nonsence to me.. ;)
You could use it though, you won't need a clutchbell.. Just get the heavy duty 2nd speed gears and you should be fine..
You do need the mechanical brake with both gearboxes.
I thought you allready knew, that in the conversion kit is a special shaft, that replaces the 2speed and locks it in 1st speed..? (we discussed this earlier)
toby
toby's Avatar
09.07.2005, 07:29 AM
hmm, i must of completley forgot. i am going to tanke anodizing off tonight though. So in the conversion it has it but i am not using the conversion. i am making my own. Than what do i do?
rc18mt/blade cp
toby
toby's Avatar
09.09.2005, 03:46 PM
ok, so far i have thought of this. i am just going to lock it out so i do not need a break servo.
SHould i go matched cells? or just normal gp3300?
Also, are the batteries held in by just strong velcro?
rc18mt/blade cp
squeeforever
squeeforever's Avatar
09.10.2005, 04:00 PM
i would get the matched ibc 3800s from mike. there about 35 a pack if memory serves correct.
toby
toby's Avatar
09.19.2005, 11:53 AM
what should the savage be geared at so i can order the proper spur?
rc18mt/blade cp
Serum
Serum's Avatar
09.19.2005, 12:41 PM
how much cells and are you going to use the two speed transmission/mechanical brake? or the single speed fixed shaft?
toby
toby's Avatar
09.19.2005, 03:03 PM
16 cells with mechanical break and two speed i was thinking.
rc18mt/blade cp
