Just go Play
Just go Play's Avatar
03.21.2008, 06:06 AM
Originally Posted by DickyT View Post
I was talking about the center diff, I do not have diff lock in the front or rear, They still have oem grease in them, and the lock lube does not lock center i can freely move it by hand. It is a hair thicker than 500k, but does not lock like silly putty would. the fronts balloon horribly. I've gotten a bit more used to it and can get fast acceleration with out wheelies now, but at WOT with all 4 planted the fronts still turn into dinner plates. I put the spool back in and all it wants to do is wheelie at any speed.
I'm in the same boat with you Dicky. For the moment I have chosen to run the solid center shaft as I just lose too much power using the CD. I don't think that there is a way to get the revo CD to work well using the 1Y on 5s as it is just too much power for it to handle.
I have found that by using a little punch control and carefully setting the slipper that so long as I don't nail the throttle the wheelies are not too big a problem. I'm also toying with a couple ideas for using a 1/8 scale CD which will handle the power better and should be a much better solution.
