Thread Tools Rating: Thread Rating: 27 votes, 5.00 average. Display Modes
03.24.2008, 10:35 AM
If you want to use Hyperion taps to make the adaptor, you'll have to replace the Kokam connectors with Hyperion connectors on the packs. Just replace one balancer wire at a time (to prevent shorting), and you should be fine. I don't know how this will affect your warranty though since you are modifying the packs.
Alternatively, you could make your adaptor with male Kokam taps on one end (the pack-end), and use a Hyperion connector on the other end (balancer end). This would require no pack modification.
The principle is exactly the same no matter what connector you use. I can't think of any adaptor that cannot be made, it just takes a little time. Just make sure you have the wires in the right order and you'll be fine...
