azjc
03.24.2008, 12:01 PM
Originally Posted by PowerRocks View Post
I wonder why people don't put an inline fuse between the battery and the esc. Use a fast blow fuse with the esc max amp. Probably need another one for the ESCs maximum continuos amp rating, but make it a delay type so that we can still acomodate the amp spike during acceleration.
I am thinking the Quarks esc fried due to internal heat, I have seen people needing to run external heat sinks and fans if they are running them above a 4s....that isnt very impessive for an esc that is suposed to be able to handle 6s....has anybody tried running an external UBEC and disable the units BEC....since I wasn't present when Dicky T's esc fried I don"t know everything that happened so its only a guess
Since I went to using the CC BEC and 4 cell lipo withe the Fiegao motor the heat to the MM is almost non existent
