DickyT
12.12.2008, 08:07 PM
Originally Posted by cdis View Post
Being told dates, then having them pushed back for no given reason is just not cricket.
I just had an overwhelming sense of deja vu.
Mozzy
Mozzy's Avatar
12.10.2008, 11:29 AM
When on earth are these going to be shipping???
I got the screw holes email weeks ago.
Where are my motors????
Losi SCTE SC4 Pro 4000kv, Tekin RX8, 2S
MP7.5 Kanai III Tekno Neu 1515/2.5D 1700kv MM 4S
LST 2 Carbon CC 1717 1Y 1580kv MM 6S
Futaba 3PKS Spektrum Pro
bruce750i
bruce750i's Avatar
12.12.2008, 08:03 PM
Don't say the word Christmas, it will be the next reason for a delay.
Unsullied_Spy
Unsullied_Spy's Avatar
12.13.2008, 07:16 PM
Nice! Mine should be here very soon, I got my order in really early.
Mozzy
Mozzy's Avatar
12.13.2008, 08:20 PM
Hmmmm, I hope mine get here soon too.
That looks HUGE over the 60mm, if that is one. What one did you get?
gogglespaesano
gogglespaesano's Avatar
12.13.2008, 09:41 PM
Krawlin, I preordered mine on oct. 14 and they charged my account that day. I payed with paypal though.
Still waiting on mine.
slash_48
slash_48's Avatar
12.15.2008, 01:14 AM
Do you think the medusa 4800 v2 will work in a slash with the mamba max esc.
Unsullied_Spy
12.15.2008, 02:22 AM
Should work fine on both 2s and 3s. It'll be rough on parts but it'll be plenty powerful.
slash_48
slash_48's Avatar
12.15.2008, 06:35 PM
How does the Medusa 4800 compare to the castle 5700 power wise.
12.15.2008, 09:14 PM
Medusa is 4 pole, cc5700 is 2 pole, so you get alot more torque with the M.
4800kv vs 5700kv so the castle motor will be faster on the same voltage, but you would use the extra torque of the Medusa to let you gear taller with less heat to worry about in principle. Depends which vehicle you stick the motor in, and which size motor you choose exactly as the cc36 motors are only S can really.
12.16.2008, 11:09 AM
...the cc36 motors are only S can really.
As stated above, the CC motors have shorter coil area than the 50mm Medusa. The Medusa coils leave about 5-8mm on each end of the case, whereas the CC motors leave about 20mm on one end (room for the connection between the coil wires and the noodle wire) and 5-8mm on the other. So, the CC is kinda a "sub-S" motor.
Other differences:
Medusa = 4 pole, CC = 2 pole (as you said)
Medusa = slotted stator, CC = slotless stator
Unsullied_Spy
12.16.2008, 02:05 AM
Medusa motors also have longer rotors and coils, giving them more torque. Mamba motors are good, but it depends on what you're going to put it in.
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
12.16.2008, 08:31 AM
Anyone one had a chance to run the 80mm yet? How do they compare to an equivalent kv rated Feigao XL. Especially temps wise.
12.16.2008, 12:04 PM
Bleedin' know-it-all..
If Im right in guessing that this is an enguiry for the Slash's ideal motor, I'd say the medusa 50 or 60mm motor is plenty really.
12.16.2008, 12:32 PM
Every place has at least one!
My Slash had a 5700 running on 10 cells (geared 58/13) and it got kinda hot running it for the ~15 minutes the batteries would last. I recently got a Medusa 36-50-2200 and will run that on 4s 5Ah cells, but am still waiting for other parts to finish it. Once they do, I can get results, but I anticipate good things...
