The crt has buggy ratio diffs, 43/13. So he is way overgeared, with the 46/12. I have a crt and will upgrade it to the HB truggy diffs, 43/10, and run 46/13 primary gearing.. Stock spur on the crt is 62t. So changing back to that spur and running a 12t hardened pinion would do the same as the truggy diffs. Give that a try if you can, and see how it does!
