GO-RIDE.com
04.10.2008, 02:49 PM
Originally Posted by miniGranis View Post
This is probably a "I should have guessed" kind of question, and I have tried to google it but I havent found anything usefull.
Here we go: When you guys refer to piston #13 or #14 where do I find the pistons ?
How many different ones are there, I have only found references to #1-3 at buytraxxas.com
5 sets of pistons came with my Revo shock kit. There were 3 for the Revo (black) labeled 1, 2, 3. There were 2 for the Jato (grey) labeled 1.3, 1.4, and refer to the size of the holes in mm. I started with the 1.3mm holes and they felt over damped. I'm now using the 1.4mm holes with 30wt and they are pretty good.
E-8ight - Tekin RX8 2000kv/4S
bustitup
11.14.2008, 06:00 PM
would these work in the front?
http://cgi.ebay.com/ws/eBayISAPI.dll...m=110311279634
GO-RIDE.com
11.14.2008, 06:30 PM
Those are the right shock bodies, but the springs and pistons will be too stiff for a crt.5. You need the Jato (1.4mm hole) pistons and Jato (pink 1.4) springs to work with the CRT.5.
bustitup
11.14.2008, 08:15 PM
if I get the jato plastic ones at tower i wont need the 1.4 jatp pistions?...just the 1.4 pink springs
GO-RIDE.com
11.14.2008, 09:16 PM
That is correct, but pistons are super cheap. Amain has a 6 pack of pistons (1.3, 1.4, 1.5) for $3, or you can drill out the Slayer/Revo pistons that come with the shocks.
bustitup
11.14.2008, 10:00 PM
well in that case I will get the revo/slayer shocks ...i kind of like the aluminum bodies..... thaks man very helpfull
Jason
06.26.2009, 11:56 PM
here my shock setup it wont work better then the stock shock for me .. when I run over bump the rear end goes up in the air and sometime flip and it REALLY dont do jump fine...
front shock is electric revo aluminium body and titanium shaft white soft spring with piston black 2 holes and AE 35WTS SHOCK OIL.
rear shock is front jammin X1-CRT shocks with white soft spring + white 2 holes piston and AE 50WT SHOCK OIL.
Jason
06.28.2009, 09:21 PM
rhinopole
10.15.2009, 05:45 PM
Does anyone know if these will fit?
http://cgi.ebay.com/NEW-2-4GHZ-REVO-...item1c0ca515d6
Thanks.
GO-RIDE.com
10.15.2009, 07:52 PM
Thanks.
Those will fit, but you will need the softer Jato springs.
BUSAFIED
10.19.2009, 11:36 PM
there's your prob right there, Jason...
for the revo front shocks, use the Jato pink springs and the #2 piston. You can vary your shock weight from 25-27.
In the rear, use the soft springs for the buggy front and use 25-27 weight oil.
Another option that I found that works pretty darn good is using 1/10 Stadium Truck shocks (preferably aluminum) in the rear with the .5 blue springs and about 35wt oil.
feel free to PM for further info. :thumbsup:
