Questions???
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Questions??? - 04.12.2008, 12:17 PM
I do believe from the posts here that most think you should avoid the FD built rig and build your own custom vehicle. This is a decision that of course only you can make for your own satisfaction. Look, you have to pull everything you can from our experiences and figure out if you are up for the task of building/converting your own truck. Surely there is plenty of help in here to get you through any rough spots. There is a lot of talent here and there is nothing that can not be overcome by the guys who post here. You will gain alot of experience from building your own, and have much more fun once it is completed. If you are up for the task and have the time for the project, then go for it. If not then spend your hard earned money as wisely as you can for something that someone else has built. Take your time, think your project through, and build it to the best of your ability. Have fun and enjoy whatever gifts that you have been given. Good luck with that.
