JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
04.16.2008, 04:57 PM
Originally Posted by speedy View Post
ok :) But if a setle for 6000w ? then i chouden't need more than 136amps on 12s ? or choud i go fo an 15s setup insted ?then i don't need more than 110Amps.
How mutch woud this setup cost me ? are 3000$ enough ?
Anything is possible, but I don't think you will do this with only $3K. It sounds like you are going to have to go big and $3K may get you started with batts, and a good motor, but that kind of power is going to kill your truck and show you weak points in your rig that have never seen BL power. Batteries alone will probably run you in the $1K to $2K range for that level of voltage and mah with enough amperage to do the 6000 or 8000 watts. Personally I hope you find ways to do it for $2K. This project sure does sound like a lot of fun though. I was thinking about getting an XTM MMT myself and converting it. So your leading the way for ideas. Thanks for sharing this with all of us. Good luck with that.
