MetalMan
MetalMan's Avatar
04.18.2008, 12:59 AM
How about some sort of "idler" gear between the pinion and spur? Might help solve motor fitment issues without having to gear so tall. Don't know if it's feasible...
That's something I hadn't thought of. TBH, if I went with an idler I think I would just throw a slipper clutch in there as well and call it a day - but then I'd still need that 20t pinion anyways . One idea I had was to drop in some truggy diffs, with their lower ratio of 4.3:1. With an 18t pinion and 10s A123, that'd put the top speed at a much more respectable ~54mph, which is still way too fast for typical bashing.
I need to see a picture of this setp... I am trying to figure out why the motor would hit the outdrive with less that 46/20...
I have seen 46/12 run on buggies and truggies without hitting the dif outdrive. Why is this different?
Like linc said, it's a 45mm motor. This was a tough shot to take (and because I was too lazy to remove the chassis brace):
I could definitely get away with an 18t pinion, but I dunno about anything lower.
